Asus rog g713qy laptop fans not running
hi guys
fans not audible, no readings from lmsensor etc
  Kernel: 6.15.0-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: hpet
    avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
    root=UUID=36a4df70-88d1-4bbb-b484-949eeef22b8e rw rootflags=subvol=@ quiet splash amdgpu.dc=1
    loglevel=3 sysrq_always_enabled=1 zswap.enabled=1 zswap.compressor=zstd
    zswap.max_pool_percent=50 preempt=full nohz_full=all threadirqs mitigations=off ibt=off
  Desktop: Hyprland v: 0.49.0 with: waybar tools: avail: swayidle,swaylock vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: ROG Strix G713QY_G713QY v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: G713QY v: 1.0 serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends LLC. v: G713QY.331 date: 02/24/2023
  ID-1: BAT0 charge: 32.4 Wh (50.1%) condition: 64.7/90.0 Wh (71.9%) power: 35.5 W volts: 14.6
    min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion serial: <filter> status: discharging
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 3
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80)
    stepping: 0 microcode: 0xA500011
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2012 min/max: 413/4893 boost: enabled scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 2012 2: 2012 3: 2012 4: 2012 5: 2012 6: 2012 7: 2012 8: 2012
    9: 2012 10: 2012 11: 2012 12: 2012 13: 2012 14: 2012 15: 2012 16: 2012 bogomips: 105403
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M
    XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    empty: DP-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0380
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 08:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 65.0 C
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: Hyprland
    v: 0.49.0 driver: X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: 1
  Monitor-1: eDP-1 model: BOE Display 0x0a13 built: 2021 res: mode: 2560x1440 hz: 165
    scale: 100% (1) dpi: 171 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
    modes: max: 2560x1440 min: 640x480
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1
    drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.1-arch1.2 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.63 6.15.0-1-mainline)
    device-ID: 1002:1638 memory: 500 MiB unified: no
  API: Vulkan v: 1.4.313 layers: 9 device: 0 type: integrated-gpu name: AMD Radeon Graphics
    (RADV RENOIR) driver: mesa radv v: 25.1.1-arch1.2 device-ID: 1002:1638 surfaces: N/A device: 1
    type: discrete-gpu name: AMD Radeon RX 6800M (RADV NAVI22) driver: mesa radv v: 25.1.1-arch1.2
    device-ID: 1002:73df surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits)
    driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo gpu: amdgpu_top,radeontop wl: kanshi,
    wdisplays, wlr-randr x11: xprop,xrandr
 Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1
  Device-3: Advanced Micro Devices [AMD] Audio Coprocessor vendor: ASUSTeK driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.5
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.6
  API: ALSA v: k6.15.0-1-mainline status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.4 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter vendor: AzureWave
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961
  IF: w0 state: up mac: <filter>
  Info: services: NetworkManager, nginx, smbd, sshd, systemd-timesyncd, wpa_supplicant
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Local Storage: total: 1.84 TiB used: 779.59 GiB (41.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: PNY model: CS2241 1TB SSD size: 931.51 GiB
    fw-rev: CS224C10 temp: 43.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB
    fw-rev: FXM7201Q temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 155.2 GiB size: 155.19 GiB (100.00%) used: 115.45 GiB (74.4%) fs: btrfs
    dev: /dev/nvme1n1p6 maj-min: 259:10
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 64.7 MiB (21.6%) fs: vfat
    dev: /dev/nvme1n1p1 maj-min: 259:6
  ID-3: /home raw-size: 155.2 GiB size: 155.19 GiB (100.00%) used: 115.45 GiB (74.4%) fs: btrfs
  ID-4: /var/log raw-size: 155.2 GiB size: 155.19 GiB (100.00%) used: 115.45 GiB (74.4%)
    fs: btrfs dev: /dev/nvme1n1p6 maj-min: 259:10
  ID-5: /var/tmp raw-size: 155.2 GiB size: 155.19 GiB (100.00%) used: 115.45 GiB (74.4%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 30.75 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
  ID-2: swap-2 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2 file: /2/swapfile
  System Temperatures: cpu: 69.1 C mobo: 52.0 C
  Fan Speeds (rpm): cpu: 0
  GPU: device: amdgpu temp: N/A V: 0.00 device: amdgpu temp: 61.0 C mem: 58.0 C fan: 0
    watts: 5.00
  Memory: tota
l: 32 GiB note: est. available: 30.75 GiB used: 6.64 GiB (21.6%)
  Processes: 532 Power: uptime: 11m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.27 GiB
    services: upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1891 libs: 405 tools: octopi,pacseek,pamac,paru,yay pm: flatpak
    pkgs: 0 Compilers: clang: 19.1.7 gcc: 15.1.1 Client: shell wrapper v: 5.2.37-release inxi: 3.3.38
  System install date:     2024-11-14
  Last full system update: 2025-06-06
fixed.
asus_wmi module wasnt automatically loaded on boot. NO IDEA WHY LOL?
i added it to systemd and fans finally work.
