Hi, I’m newer to Garuda and can’t get my wireless adapter working (ASUS AC1200 USB-AC53 Nano). They are no officially supported drivers for Linux but I also can’t seem to make the windows drivers work through ndiswrapper. (I assume just because the device is newer).
Running Kernel 5.11.1 on the most updated version of Garuda dragonized.
If anyone knows any drivers out for this or ways to get ndis to accept the drivers that would be great.
I also do have access to the internet on the system via dragging it 10 feet from the router but would prefer not to sit on the floor next to it for the rest of its use
Thank you, do I need to add these drivers to a specific folder or config file? I downloaded/installed them like any AUR package and I’m just trying to make sure that it’s not something on my end before I go try and scout out new drivers
The package is in the ChaoticAUR repository so you can install them like any standard package. You can use the AUR package if you want. But, once installed, that should be it.
If something isn’t working then post details, steps, and output.
git clone https://aur.archlinux.org/packages/rtl88x2bu-dkms-git/
cd rtl88x2bu-dkms-git
makepkg -si
Package installed with no failures.
my output from ipLink is
lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp5s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether a8:a1:59:49:2f:57 brd ff:ff:ff:ff:ff:ff
3: wlp2s0f0u2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DORMANT group default qlen 1000
link/ether 22:fc:0d:d6:74:3a brd ff:ff:ff:ff:ff:ff permaddr a8:5e:45:ee:c7:18
My outputs from lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0b05:184c ASUSTek Computer, Inc. 802.11ac NIC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
If there is any other output you guys would like or would make troubleshooting easier let me know.
Your kernel headers for kernel 5.11.1-zen1-1-zen cannot be found at
/usr/lib/modules/5.11.1-zen1-1-zen/build or /usr/lib/modules/5.11.1-zen1-1-zen/source.
You can use the --kernelsourcedir option to tell DKMS where it's located.
sorry if some of this troubleshooting seems basic, I have done a few pure arch installs but this is the first time I have tried to daily an arch platform.
