Are all linux kernel versions uniform? (steering wheel trouble)
hey
im new to linux
got everything running after few days
except my steering wheel(g923 trueforce(xbox/pc) )
it isn,t detected by oversteer
but it does show when i run dmesg
{397.575048] usb 5-2: new full-speed USB device number 7 using xhci_hcd
[  397.740084] usb 5-2: New USB device found, idVendor=046d, idProduct=c26d, bcdDevice=39.01
[  397.740087] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  397.740088] usb 5-2: Product: G923 Racing Wheel for Xbox One and PC
[  397.740089] usb 5-2: Manufacturer: Logitech
[  397.740090] usb 5-2: SerialNumber: 00007b8a5505faa8
[  636.850670] BTRFS info: devid 1 device path /dev/disk/by-uuid/c977e049-2932-49d5-b727-a143f329dd33 changed to /dev/nvme0n1p2 scanned by mount (27195)
[ 3614.945182] usb 5-2: USB disconnect, device number 7}
oversteer mentions it being supported by a in-kernal hidpp after a patch would be upstreamed
but no clear conformation can be found on that
after a lot of time i found this
[GIT PULL] HID for 6.3 — Linux Kernel
which mentions it for 6.3
the zen kernel (which i run) shows 6.3.3.zen1-1
is that the same as the linux 6.3 version?
i mean maby cus it already shows it is connected
but then i am completly stuck on why it won,t work
should i not be looking toward oversteer due to this hidpp thingy ?
am i missing something here ??
i would love any advice on it
much love
Sky
I’m not a specialist, but if they were all the same, there would only be one kernel.
Much more important for us as
would be if you would follow the template and post your garuda-inxi.
Ending posts with your name is neither necessary, it is already next to your post, nor desirable. :slight_smile:
ah my bad sorry bout that
it was not my intention
i do it right
i hope this is more proper
  1. The issue
    my steering wheel (g923 trueforce(xbox/pc) is not working
    oversteer does not reconise it and games do not see it
  2. Attempts to solve it
    i reinstalled oversteer
    reinstalled hidapi
    installed linux lts and linux kernel
    have done a lot of searching for a way to get it working
    i tried new-lg4ff but it wasn,t for this wheel
    read on oversteer github that there was a patch for it waiting
    found patch note aka pull request
    tried steam controller settings
    tried to find device in garuda game controllers (it was not there )
    tried to find oversteer alternative on opticy but no luck
  3. System information
Kernel: 6.3.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c977e049-2932-49d5-b727-a143f329dd33 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Desktop System: Gigabyte product: X570S AORUS ELITE AX v: -CF
serial: N/A
Mobo: Gigabyte model: X570S AORUS ELITE AX v: x.x serial: N/A
UEFI: American Megatrends LLC. v: F6b date: 03/23/2023
Info: model: AMD Ryzen 7 5800X3D socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3665 high: 4450 min/max: N/A base/boost: 3400/3400
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3574 2: 3597 3: 3602 4: 3584
5: 3597 6: 3600 7: 3599 8: 3799 9: 3559 10: 3597 11: 3644 12: 3594
13: 3597 14: 3848 15: 4450 16: 3400 bogomips: 108798
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: PNY
status: current (as of 2023-05) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 0a:00.0 chip-ID: 10de:2216 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x402mm (27.83x15.83")
s-diag: 813mm (32.02")
Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 93
size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: PNY
bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-3: Corsair VOID PRO Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 3-3.3:5 chip-ID: 1b1c:0a1a class-ID: 0300
API: ALSA v: k6.3.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.71 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-5:2 chip-ID: 0e8d:0608
address: <filter>
Local Storage: total: 2.73 TiB used: 524.71 GiB (18.8%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
SMART: yes health: PASSED on: 51d 4h cycles: 399
read-units: 13,878,673 [7.10 TB] written-units: 29,198,436 [14.9 TB]
model: WD2003FZEX-00SRLA0 family: Black size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 174d 6h cycles: 2692
used: 147.31 GiB (15.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.24 GiB used: 2.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 52.9 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 423 Uptime: 2h 42m wakeups: 0 Memory: available: 31.24 GiB
used: 6.48 GiB (20.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1763
libs: 542 tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date:     2023-05-23
Last full system update: 2023-05-24
sorry bout the 50 edits had some trouble there
Apologies if this is a dumb question, but did you actually boot the LTS kernel? Installing it doesn’t have any effect on its own, you have to select the kernel from the advanced boot options of the Grub menu.
This minute...
linux 6.3.4
linux-zen 6.3.4
linux-lts 6.1.30
