:: archlinux-appstream-data-pamac and archlinux-appstream-data are in conflict. Remove archlinux-appstream-data? [y/N] N
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Result INXI:
System: Kernel: 5.10.42-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=017f6204-0483-4365-a104-5c12b37f9938
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Portable System: Dell product: Inspiron 5735 v: A02 serial: <filter> Chassis: type: 8
Mobo: Dell model: 04VD0G v: A00 serial: <filter> UEFI: Dell v: A02 date: 08/23/2016
Battery: ID-1: BAT1 charge: 19.7 Wh (100.0%) condition: 19.7/66.6 Wh (29.6%) volts: 12.7 min: 11.1
model: LGC DELL 0MF693AA type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: AMD A8-5545M APU with Radeon HD Graphics bits: 64 type: MCP
arch: Piledriver family: 15 (21) model-id: 13 (19) stepping: 1 microcode: 6001119 cache:
L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 13574
Speed: 1552 MHz min/max: 1100/1700 MHz boost: enabled Core speeds (MHz): 1: 1552 2: 1540
3: 1497 4: 1404
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Richland [Radeon HD 8510G] vendor: Dell driver: radeon v: kernel bus-ID: 00:01.0
chip-ID: 1002:9999 class-ID: 0300
Device-2: Suyin Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 2-5:3
chip-ID: 064e:812e class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: ati,radeon
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1")
Monitor-1: eDP res: 1600x900 hz: 60 dpi: 106 size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.10.42-1-lts LLVM 11.1.0) v: 4.3 Mesa 21.1.1
compat-v: 3.1 direct render: Yes
Audio: Device-1: AMD Trinity HDMI Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.29 running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Dell driver: ath9k
v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
Bluetooth: Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:7
chip-ID: 0cf3:0036 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 298.09 GiB used: 87.14 GiB (29.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545032B9A300 size: 298.09 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: C60F
Partition: ID-1: / raw-size: 75 GiB size: 75 GiB (100.00%) used: 18.73 GiB (25.0%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 560 KiB (0.1%) fs: vfat
dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 210.09 GiB size: 209.98 GiB (99.95%) used: 68.41 GiB (32.6%) fs: xfs
dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 75 GiB size: 75 GiB (100.00%) used: 18.73 GiB (25.0%) fs: btrfs
ID-5: /var/tmp raw-size: 75 GiB size: 75 GiB (100.00%) used: 18.73 GiB (25.0%) fs: btrfs
ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 1.74 GiB used: 26.6 MiB (1.5%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.74 GiB used: 26.5 MiB (1.5%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.74 GiB used: 26.5 MiB (1.5%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.74 GiB used: 26.6 MiB (1.5%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 56.5 C mobo: N/A gpu: radeon temp: 55.0 C
Fan Speeds (RPM): cpu: 3200
Info: Processes: 225 Uptime: 7d 9h 07m wakeups: 3 Memory: 6.97 GiB used: 4.25 GiB (61.0%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0 Packages:
pacman: 1434 lib: 356 Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
After that whole -- resent -- pacman issue, I was finally able to update my system; so I thought.
After fixing my pacman.conf file with pacman issue, I started to update (pacman -Syu); but a ALSA LIB conflict came up; enabling multi-lib in pacman.conf resolved that.
As Steam uses a 32-bit library for ALSA, I enabled using "multi-lib" in my pacman.conf file; resolved.
Then this error came up: "archlinux-appstream-data-pamac and archlinux-appstream-data are in conflict"; as posted above...
After resolving the pacman and ALSA lib issue, I still can't update my system.
Searching Arch and Garuda forums were not helpful, nor was searching the internet. The only thing I found were bug reports, general information about appstream-data, and other not-helpful stuff.
I found this thread here on the Garuda forums, but doesn't seem to address the concern I'm having.
(1) Add / Remove software doesn't show anything
(2) FIXED Pamac (Add/Remove Software) does not launch
Other than bug reports (non-relevant), or AUR pages regarding appstream; I haven't found anything useful.
Any suggestions?
Thanks!
