Apps not showing in system tray
Is there an option somewhere that we have to enable to make things like discord, corectrl etc show in system tray? im on gnome. also i cant move the notification to center from top left.
you can use alltray to show all apps in systemtray there are some options but it was not what i wanted with thunderbird that it automatic starts in tray and return after use
the commands from alltray i found are a little bit old and not aligned for garuda
maybe someone can help
