Hello.
inxi -Faz
inxi -Faz
System: Kernel: 5.10.63-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d571e53c-e48f-42fb-9c55-e00ece8b194b rw rootflags=subvol=@ quiet splash
resume=UUID=ce7c333e-5121-4e0b-a7ec-c5de088dbc9a loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion dv4 Notebook PC
v: 0497200000241810100020000 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 140A v: 50.17 serial: <filter> BIOS: Insyde v: F.0B
date: 02/24/2010
Battery: ID-1: BAT0 charge: 0% condition: 47.5/47.5 Wh (100.0%) volts: 3.5 min: 10.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525 serial: <filter>
CPU: Info: Dual Core model: Intel Core i5 M 430 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 25 (37) stepping: 2 microcode: 11 cache: L2: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18089
Speed: 1507 MHz min/max: 1199/2267 MHz boost: enabled Core speeds (MHz): 1: 1507
2: 1658 3: 1735 4: 1493
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: Intel Core Processor Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: Syntek USB Camera Device type: USB driver: uvcvideo bus-ID: 2-1.5:4
chip-ID: 174f:1107 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: kwin_x11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.2.1
direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio
chip-ID: 8086:3b56 class-ID: 0403
Sound Server-1: ALSA v: k5.10.63-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
Network: Device-1: Broadcom BCM43225 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma port: 6000 bus-ID: 02:00.0 chip-ID: 14e4:4357
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: N/A modules: r8169 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8136
Drives: Local Storage: total: 223.57 GiB used: 9.17 GiB (4.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: OCZ model: ARC100 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 1.01 scheme: MBR
Partition: ID-1: / raw-size: 215.55 GiB size: 215.55 GiB (100.00%) used: 9.17 GiB (4.3%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 215.55 GiB size: 215.55 GiB (100.00%) used: 9.17 GiB (4.3%)
ID-3: /var/log raw-size: 215.55 GiB size: 215.55 GiB (100.00%)
used: 9.17 GiB (4.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 215.55 GiB size: 215.55 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 3.64 GiB used: 0 KiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 61.0 C mobo: N/A
Info: Processes: 197 Uptime: 2m wakeups: 3 Memory: 3.64 GiB used: 1.41 GiB (38.7%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
Packages: pacman: 815 lib: 231 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
I am new to garuda, trying to make my switch from debain. I came across a post about application menubar but do not understand what file the use is modifying under .config? I understand that I went with KDE barebone and support would be limited.
Please help me to get through this simple issue.
Thanks.
