Hello,
Since I installed garuda, I have an issue with latte dock. I tried to search online, but just didn't know, how to describe it in short terms.
The issue:
sometimes, when I move my cursor to the dock, it shows all pinned applications. All the other currently open applications reload about a second later. They are not showing up instantly with the pinned ons
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=83389f09-599d-44dc-986f-e6c7e12ec2e6 rw [email protected]
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1560
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1560 serial: <superuser required>
UEFI: HUAWEI v: 1.06 date: 09/14/2020
ID-1: BAT0 charge: 49.6 Wh (99.6%) condition: 49.8/54.9 Wh (90.7%)
volts: 8.4 min: 7.6 model: DYNAPACK HB4593R1ECW-22T0 type: Li-ion
serial: <filter> status: discharging cycles: 173
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600104
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2214 high: 2900 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2900 2: 2900
3: 2900 4: 2900 5: 1396 6: 2900 7: 1397 8: 2900 9: 1398 10: 2550 11: 1398
12: 2900 13: 1397 14: 1305 15: 1397 16: 2900 bogomips: 92630
protection
Device-1: AMD Renoir driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 37.0 C
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 13d3:5451 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 2160x1440 s-dpi: 96 s-size: 571x381mm (22.48x15.00")
s-diag: 686mm (27.03")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0893 built: 2019
res: 2160x1440 hz: 60 dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76")
diag: 356mm (14") ratio: 3:2 modes: max: 2160x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.10-zen2-1-zen) direct render: Yes
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725
IF-ID-1: br-5088cde0f52b state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: veth1a68b47 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: veth70cbf49 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethe92eb7b state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 931.51 GiB used: 386.95 GiB (41.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 706.72 GiB size: 706.72 GiB (100.00%)
used: 386.92 GiB (54.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.3 MiB (30.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 706.72 GiB size: 706.72 GiB (100.00%)
ID-4: /var/log raw-size: 706.72 GiB size: 706.72 GiB (100.00%)
ID-5: /var/tmp raw-size: 706.72 GiB size: 706.72 GiB (100.00%)
ID-1: swap-1 type: zram size: 15 GiB used: 1.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 38.9 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 425 Uptime: 9m wakeups: 3 Memory: 15 GiB used: 7.37 GiB (49.2%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1947 libs: 547 tools: octopi,paru
Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.23
e[1;34mGaruda (2.6.10-1):e[0m
e[1;34m System install date:e[0m 2022-10-24
e[1;34m Last full system update:e[0m 2022-12-03
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify) -> yes
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
