Is there a way to run any app in somekind of "diagnostic" "monitored" mode or get some logs on its errors? Usually I would get the error in the terminal but some apps do not display any error message in terminal.
I know that the Linux filesystem is full of inormation being written into files.. I need to figure out where I can get more info.
Why do i need it? I have a problem with terminal "cd" command taking .5second to complete (time delay). But it would be interesting in general to know how to diagnose app issues better.
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=bd716b39-6313-4def-bb78-fea6f3782898 rw [email protected]
loglevel=3 ibt=off
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 3604 date: 02/25/2022
Info: model: AMD Ryzen 7 2700X socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2387 high: 3700 min/max: 2200/3700 boost: disabled
base/boost: 3700/4350 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3700 2: 2200 3: 2200 4: 3700
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 118404
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:1c03 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 93 s-size: 1049x321mm (41.30x12.64")
s-diag: 1097mm (43.19")
Monitor-1: DVI-D-0 pos: primary,right res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: HDMI-0 pos: left res: 1920x1200 hz: 60 dpi: 94
API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 3-3:3 v: kernel chip-ID: 0d8c:0004 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1
chip-ID: 10de:10f1 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: C-Media CM6631A Audio Processor type: USB
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 168c:002b class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
driver: btusb v: 0.8 bus-ID: 1-2:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.62 TiB used: 52.51 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
rev: H211011a temp: 41.9 C scheme: GPT
SMART: yes health: PASSED on: 139d 23h cycles: 633
read-units: 12,896,665 [6.60 TB] written-units: 8,688,888 [4.44 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: M4-CT128M4SSD2
family: Micron RealSSD m4/C400 size: 119.24 GiB block-size: physical: 512 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 000F scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 50d 0h cycles: 6075
model: WD20EARX-00PASB0 family: Green size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: N/A
serial: <filter> rev: AB51 temp: 25 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 5y 59d 3h cycles: 5741
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
family: SSDNow UV400/500 size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 96R9 temp: 24 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 332d 13h cycles: 2353
ID-1: / raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
used: 52.48 GiB (21.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
used: 28.1 MiB (9.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
maj-min: 259:6
ID-4: /var/log raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
maj-min: 259:6
ID-5: /var/tmp raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
maj-min: 259:6
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.5 C mobo: N/A gpu: nvidia temp: 28 C
Processes: 359 Uptime: 2h 28m wakeups: 1 Memory: 15.53 GiB
used: 4.05 GiB (26.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1391
libs: 340 tools: octopi,paru,yay pm: rpm pkgs: 0 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-05
Last full system update: 2023-01-17 ↻
Windows dual boot: Yes
