Appimage WriteorDie terminated by signal SIGSEGV (Address boundary error)
Im trying to run this app:
https://writeordie.com/
i download the appimage and im getting this error:
fish: Job 1, './writeordie3-3.0.6-x86_64.AppI…' terminated by signal SIGSEGV (Address boundary error)
what can i do to fix it?
Thanks.
Please always follow the template and post your garuda-inxi.
What is this horror website?
Closed source? I can’t even find the app image :rofl:
This forum is not a general tech support forum.
Please ask the developer for help.
https://transactions.sendowl.com/orders/133132213/download/8695afd9fa6a0a8e40304a4b02924578
  Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=a3aaae26-ab38-4149-85a1-09c9afda9c1e rw rootflags=subvol=@
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: EXO S.A. product: EXO Smart XQ3h v: N/A
  Mobo: EXO S.A. model: CT15Q5-S serial: <superuser required> UEFI: WEIBU
    v: YHSM-BI-15.6-XU133TR120-TA60B-328-C date: 11/23/2021
  ID-1: BAT0 charge: 10.9 Wh (23.9%) condition: 45.6/45.6 Wh (100.0%)
    power: 17.1 W volts: 8.1 min: N/A model: WB SR 1 WB Lion Battery
    type: Li-ion serial: <filter> status: charging
  Info: model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP
    microcode: 0xAC
    L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 2.5 MiB desc: 2x1.2 MiB
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1687 high: 2475 min/max: 400/4100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1498 2: 2475 3: 2375
    4: 400 bogomips: 23961
  Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] driver: i915 v: kernel
    arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a78 class-ID: 0300
  Device-2: Sunplus Innovation Hy-UXGA-Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 1bcf:2ced
    class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting
  Monitor-1: eDP-1 model-id: STA 0xafc9 built: 2020 res: 1920x1080 dpi: 142
    gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT2)
    device-ID: 8086:9a78 memory: 7.33 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (TGL GT2) driver: mesa intel v: 23.2.1-arch1.1
    device-ID: 8086:9a78 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 23.2.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
  Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
    chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api tools: N/A
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 8086:15f3
  Device-1: IMC Networks driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 13d3:3503
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.1
    lmp-v: 7 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 238.47 GiB used: 118.13 GiB (49.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: P210 256GB
    tech: SSD serial: <filter> fw-rev: 3A0 scheme: GPT
  ID-1: / raw-size: 134.12 GiB size: 134.12 GiB (100.00%)
    used: 118.1 GiB (88.1%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
    used: 27.7 MiB (28.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 134.12 GiB size: 134.12 GiB (100.00%)
  ID-4: /var/log raw-size: 134.12 GiB size: 134.12 GiB (100.00%)
  ID-5: /var/tmp raw-size: 134.12 GiB size: 134.12 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.5 GiB used: 1.49 GiB (19.9%) priority: 100
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 250 Uptime: 3h 31m wakeups: 1 Memory: total: 8 GiB note: est.
  available: 7.5 GiB used: 4.74 GiB (63.2%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1477
  pm: pacman pkgs: 1470 libs: 438 tools: pamac,paru pm: flatpak pkgs: 7
  Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.30
  System install date:     2023-09-15
  Last full system update: 2023-10-01 ↻
Your link goes to closed source commercial software. Ask them for help. You paid for it, right?
I notice it is Beta software and you should expect bugs. Again, it’s up to them to provide help.
Nop, it is free.
Ok, thanks, I thought that maybe this could be something that can be fixed just knowing the error im getting. But anyway, thanks.
If someone could help, they would need the entire terminal output including the input command.
But why, you can’t open an issue on some git page.
