Apparmor with Zen Kernel Solution
Apparmor - Solution working with Zen Kernel
aa-enabled - Some may read - Disabled at boot
aa-status - Some may read - aa-enabled /Apparmor is not mounted
$ sudo perl -pi -e's,GRUB_CMDLINE_LINUX="(.*)"$,GRUB_CMDLINE_LINUX=" $1 apparmor=1 security=apparmor",' /etc/default/grub
$ sudo update-grub
$ sudo reboot
Follow the steps after reboot - Apparmor will be enabled
Use - sudo su - then login with root then type - aa-status - everything will show up for apparmor list and everything is enforced.
