Hey so i wanted to disable the plymouth boot screen i dont want to follow guides for ubuntu and other distro's a black screen instead of plymouth will be acceptable a splash screen will be great
Try masking it
sudo systemctl mask plymouth-start.service
Now the plymouth screen appears for like 2 seconds after the dragon splash screen appears.
Also get rid of the plymouth
in /etc/mkinitcpio.conf & remove splash
& quiet
from /etc/default/grub. Then run mkinitcpio -P && sudo update-grub
and reboot afterwards.
I did the following but still get plymouth
Thats not possible (afaik), did you reboot?
yes thats how i checked if its still there
Also remove any package containing plymouth from the system (pacman -Qs plymouth
lists those). Even though it should not show up anymore since its kernel parameters are disabled
Just to be sure, output of cat /etc/mkinitcpio.conf | grep plymouth
& cat /etc/default/grub | grep splash
I'd suggest you spend some time familiarising yourself with the resources available for Arch and Arch-derived distributions:
https://wiki.archlinux.org/title/Plymouth
The majority of questions you have asked so far have been answered already, whether on this forum, forums of other Arch-derived distros, or within the Arch wiki.
Also keep in mind that you are asking for help dismantling the defaults crafted by the Garuda maintainers so if (when) you break your setup don't expect any sympathy.
