Ankur's garuda inxi
 ╭─[email protected] in ~
 ╰─λ garuda-inxi
  Kernel: 5.17.3-5-bore arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-bore
    root=UUID=3d8862a3-cc90-4161-81ad-195e8064062c rw [email protected]
    loglevel=3 quiet splash systemd.unified_cgroup_hierarchy=1
    sysrq_always_enabled=1
  Desktop: sway v: 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
  Type: Laptop System: Dell product: Inspiron 7570 v: N/A
  Mobo: Dell model: 06K08K v: A00 serial: <superuser required> UEFI: Dell
    v: 1.22.0 date: 12/14/2021
  ID-1: BAT0 charge: 21.2 Wh (100.0%) condition: 21.2/42.0 Wh (50.5%)
    volts: 12.7 min: 11.4 model: Samsung SDI DELL CYMGM79 type: Li-ion
    serial: <filter> status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
  Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1789 high: 1801 min/max: 400/4000 scaling:
    driver: intel_pstate governor: performance cores: 1: 1800 2: 1800 3: 1758
    4: 1798 5: 1767 6: 1794 7: 1800 8: 1801 bogomips: 32026
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nouveau
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
    driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:28c1 class-ID: 0e02
  Display: wayland server: Xwayland v: 22.1.1 compositor: sway v: 1.7
    driver: gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: BOE Display 0x06b4 built: 2016 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
  Message: Wayland GBM/EGL data currently not available.
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  Sound Server-1: ALSA v: k5.17.3-5-bore running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
    bus-ID: 1-7:4 chip-ID: 8087:0a2a class-ID: e001
    v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
    class-ID: 0104
  Local Storage: total: 1.14 TiB used: 59.07 GiB (5.0%)
    speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3
  ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 SATA 256GB
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: L003 scheme: GPT
    used: 59.07 GiB (6.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
    used: 588 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: zram size: 7.51 GiB used: 2.5 MiB (0.0%) priority: 100
  System Temperatures: cpu: 46.0 C pch: 46.5 C mobo: 46.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 2545
  Processes: 255 Uptime: 42m wakeups: 4 Memory: 7.51 GiB
  used: 2.3 GiB (30.6%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1569 lib: 475 Shell: fish
  v: 3.4.1 running-in: foot inxi: 3.3.15
Garuda (2.6.2-1):
  System install date:     2022-04-30
  Last full system update: 2022-05-01
  Failed units:            systemd-guest-user.service systemd-oomd.socket
 ╭─[email protected] in ~ took 3s
 ╰─λ
:slight_smile:
