Alacritty doesn't open when you have multi-monitors that uses different refresh rates
I have 1 monitor which is 4k 60hz and another monitor which is 1440p 170hz
This is on a fresh install of Garuda (Gaming edition)
if I set my 1440p monitor to 60hz, it works fine, but then you defeat the purpose of using a high refresh rate monitor
other things I've tried was changing the kernal to linux
and the driver to nvidia
(I downloaded the package, but didn't see option to select in settings -> hardware config
), was able to change kernal on startup, since it didn't let me in settings -> kernal
this had no effect.
This isn't really a huge issue, since I can just use another terminal emulator, or change refresh rate when I want to play games, but would be nice if I don't have to do that
when you run alacritty -vvv
[2021-10-09 13:44:51.788745833] [INFO ] [alacritty] Welcome to Alacritty
[2021-10-09 13:44:51.788781293] [INFO ] [alacritty] Configuration files loaded from:
"/home/ricky/.config/alacritty/alacritty.yml"
[2021-10-09 13:44:51.798472378] [TRACE] [crossfont] Number of fonts is 172
[2021-10-09 13:44:51.798493489] [TRACE] [crossfont] Got font path="/usr/share/fonts/TTF/Fantasque Sans Mono Regular Nerd Font Complete Mono.ttf", index=0
[2021-10-09 13:44:51.798532449] [DEBUG] [crossfont] Loaded Face Face { ft_face: Font Face: Regular, load_flags: TARGET_LIGHT, render_mode: "Normal", lcd_filter: 1 }
[2021-10-09 13:44:51.864410433] [DEBUG] [alacritty] Estimated DPR: 508
[2021-10-09 13:44:51.864444774] [DEBUG] [alacritty] Estimated window size: Some(PhysicalSize { width: 420700, height: 243870 })
[2021-10-09 13:44:51.864451554] [DEBUG] [alacritty] Estimated cell size: 4207 x 8129
[2021-10-09 13:44:51.972933514] [ERROR] [alacritty] Alacritty encountered an unrecoverable error:
Error creating GL context; Received multiple errors. Errors: `[OsError("eglCreateWindowSurface failed"), OsError("Couldn't setup vsync: expected interval `1` but got `0`")]`
System: Kernel: 5.14.9-arch2-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=fe6de904-bcf1-4ad1-bee4-b5bb4dbbac1b rw rootflags=subvol=@
quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 3603 date: 03/20/2021
CPU: Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: 0 microcode: 8701021 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115232
Speed: 4019 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 4019 2: 3551 3: 3596 4: 3598 5: 3599
6: 3747 7: 3600 8: 3592 9: 3597 10: 3605 11: 3600 12: 3593 13: 3594 14: 3599 15: 3581 16: 3600
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com. driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 09:00.0 chip-ID: 10de:1b06 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.4:9 chip-ID: 046d:082d
Device-3: Oculus VR Rift CV1 Sensor type: USB driver: uvcvideo bus-ID: 5-3.3:5 chip-ID: 2833:0211 class-ID: ef00
Device-4: Oculus VR Rift CV1 Sensor type: USB driver: uvcvideo bus-ID: 6-1:2 chip-ID: 2833:0211 class-ID: ef00
Device-5: Oculus VR Rift CV1 Sensor type: USB driver: uvcvideo bus-ID: 6-4:4 chip-ID: 2833:0211 class-ID: ef00
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 104 s-size: 1250x342mm (49.2x13.5") s-diag: 1296mm (51")
Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 105 size: 621x341mm (24.4x13.4") diag: 708mm (27.9")
Monitor-2: DP-4 res: 2560x1440 dpi: 65024 size: 1x1mm (0.0x0.0") diag: 1mm (0.1")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio: Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus-ID: 09:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-3.3:7 chip-ID: b58e:9e84 class-ID: 0300 serial: <filter>
Device-4: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.4:9 chip-ID: 046d:082d
Device-5: Oculus VR Rift CV1 Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2.2:6
chip-ID: 2833:0330 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.14.9-arch2-1 running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb v: 0.8 bus-ID: 3-5:2 chip-ID: 8087:0025
Drives: Local Storage: total: 7.79 TiB used: 18.63 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 Plus size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT4P1.2 temp: 35.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST6000VN001-2BB186 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5425 serial: <filter> rev: SC60 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDBNCE5000PNC-WRSN size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10WD scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Glide size: 57.33 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 256.49 GiB size: 256.49 GiB (100.00%) used: 18.63 GiB (7.3%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 856 KiB (0.2%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
ID-3: /home raw-size: 256.49 GiB size: 256.49 GiB (100.00%) used: 18.63 GiB (7.3%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-4: /var/log raw-size: 256.49 GiB size: 256.49 GiB (100.00%) used: 18.63 GiB (7.3%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-5: /var/tmp raw-size: 256.49 GiB size: 256.49 GiB (100.00%) used: 18.63 GiB (7.3%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-1: swap-1 type: zram size: 31.26 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 38.2 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 23%
Info: Processes: 360 Uptime: 14m wakeups: 0 Memory: 31.26 GiB used: 3.39 GiB (10.9%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1698 lib: 503 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
