Hi all,
After I hopefully managed my Boot-Problems, I have to new problems:
- Alacritty does not start
I get after around one minute a completely empty window.
alacritty -vvv shows the following:
╭─mod at MOD-LINUX in /etc
╰─λ alacritty -vvv
Created log file at "/tmp/Alacritty-59497.log"
[2021-01-03 21:33:38.788569979] [INFO ] [alacritty] Welcome to Alacritty
[2021-01-03 21:33:38.788611848] [INFO ] [alacritty] Configuration files loaded from:
"/home/mod/.config/alacritty/alacritty.yml"
[2021-01-03 21:33:38.905170162] [INFO ] [alacritty] Device pixel ratio: 718.4166666666666
[2021-01-03 21:33:38.906092564] [INFO ] [alacritty] Initializing glyph cache...
[2021-01-03 21:34:20.626544488] [INFO ] [alacritty] ... finished initializing glyph cache in 41.720436714s
[2021-01-03 21:34:20.627368860] [INFO ] [alacritty] Cell size: 4462 x 9042
[2021-01-03 21:34:20.627399040] [INFO ] [alacritty] Padding: 400 x 300
[2021-01-03 21:34:20.627403690] [INFO ] [alacritty] Width: 800, Height: 600
[2021-01-03 21:34:20.630788349] [INFO ] [alacritty] PTY dimensions: Line(1) x Column(2)
[2021-01-03 21:34:20.633710103] [INFO ] [alacritty] Initialisation complete
[2021-01-03 21:34:20.741622783] [INFO ] [alacritty] Padding: 400 x 300
[2021-01-03 21:34:20.741648993] [INFO ] [alacritty] Width: 800, Height: 600
I have tried the following:
- Download new config from Gitlab and copied the config from /etc/skel, but this doesn't change anything.
- Problem with the Garuda-Setup-Assistant
As soon as I want to start it, there is a update shown. But this is not possible to install.
I shows the error that the packet is broken, or the checksum is wrong, and afterwards pacman asks to delete the file. Here the german fault:
sudo pacman -S garuda-setup-assistant
Löse Abhängigkeiten auf...
Suche nach in Konflikt stehenden Paketen...
Pakete (1) garuda-setup-assistant-r9.0e2d6a8-1
Gesamtgröße der installierten Pakete: 0,01 MiB
:: Installation fortsetzen? [J/n] J
(1/1) Prüfe Schlüssel im Schlüsselring [----------------------------------------] 100%
(1/1) Überprüfe Paket-Integrität [----------------------------------------] 100%
:: Datei /var/cache/pacman/pkg/garuda-setup-assistant-r9.0e2d6a8-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (Prüfsumme)).
Soll die Datei entfernt werden? [J/n] J
Fehler: Konnte den Vorgang nicht durchführen (Ungültiges oder beschädigtes Paket (Prüfsumme))
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
I already tried to update the chaotic-keyrings and to add manually keys like written on this page:
Thanks for your help
MOD
