How do I include new internal storage drive in the updatedb.conf file which reads as--
# Modified by Garuda Linux to exclude snapshots
PRUNEPATHS = "/afs /media /mnt /net /sfs /tmp /udev /var/cache /var/lib/pacman/local /var/lock /var/run /var/spool /var/tmp /.snapshots"
What can I safely alter? My new drive is located at /run/media/arthur/first
sudo garuda-inxi
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=15449417-b8af-455f-ac34-892500896455 rw [email protected]
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Hewlett-Packard product: HP Compaq Elite 8300 SFF
v: N/A serial: <filter> Chassis: type: 4 serial: <filter>
Mobo: Hewlett-Packard model: 3397 serial: <filter> UEFI: Hewlett-Packard
v: K01 v03.06 date: 02/12/2018
Info: model: Intel Core i5-3470 socket: BGA1155 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
desc: 1x6 MiB
Speed (MHz): avg: 1597 min/max: 1600/3600 base/boost: 3200/3800 scaling:
driver: intel_cpufreq governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 1597 2: 1597 3: 1597 4: 1597 bogomips: 25542
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ASUSTeK driver: nvidia
v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 470.xx+
status: legacy-active (EOL ~2023/24) arch: Kepler pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 10de:1287 class-ID: 0300
Display: server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 271x203mm (10.67x7.99")
s-diag: 339mm (13.33")
Monitor-1: HDMI-0 res: 1024x768 hz: 60 dpi: 63
size: 410x230mm (16.14x9.06") diag: 470mm (18.51") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 730/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.08 TiB used: 119.04 GiB (2.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU635 size: 447.13 GiB
block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4c18 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 18d 14h cycles: 390
read: 454 KiB written: 270 KiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000LM016-1N2170
family: Laptop HDD size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 0003 temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 44d 4h cycles: 2111
read: 1.12 TiB written: 11 TiB Pre-Fail: attribute: Spin_Retry_Count
used: 68.22 GiB (15.3%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.3 GiB used: 283 MiB (0.9%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 39 C
Processes: 275 Uptime: 2h 14m wakeups: 0 Memory: 31.3 GiB
used: 3.59 GiB (11.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1650 pacman: 1636 lib: 372 flatpak: 14
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: kitty
inxi: 3.3.16
e[1;34mGaruda (2.6.3-2):e[0m
e[1;34m System install date:e[0m 2022-05-03
e[1;34m Last full system update:e[0m 2022-05-22
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper (maybe)
e[1;34m Failed units: e[0m
