Adding custom resolution
Hello,
I tried all solution from google to add custom resolution through Xrandr or nvidia X server setting
I mainly was playing apex in windows on 2134x1440 custom resolution like stretched resolution
but everytime i try to use xrandr to add it in terminal i get this message
λ xrandr --addmode DP-0 2136x1440_240.00
X Error of failed request:  BadMatch (invalid parameter attributes)
Major opcode of failed request:  140 (RANDR)
Minor opcode of failed request:  18 (RRAddOutputMode)
Serial number of failed request:  43
Current serial number in output stream:  44
please help me if you have a solution
i found a manual workaround from nvidia X server is like to go to reoslution page and press advanced then change the viewportin and panning to 2134x1440 and it will work in Apex but that force me to change the desktop resolution as well to 2134x1440 as well
In windows i can add custom resolution in nvidia settings then i will find it inside apex and i can choose it without changing my desktop resolution
Missing your garuda-inxi
And we know about
Hi, see similar thread
