9acca9
8 November 2023 23:02
1
Im tryng to install this
Installing with pip i get this info:
WARNING: The scripts kbs and keyboardsounds are installed in '/home/myuser/.local/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location
if i write kbs in the terminal i get nothing.
Did you know how add the directory to PATH?
I try this:
vi ~/.bashrc
export PYTHONPATH="${PYTHONPATH}:/new/path"
replacing new path with the corresponding, but it is not working.
Thanks.
No garuda-inxi
has been posted so we can’t see what shell is in use. If you are using Fish, you can follow this document to add a component to the $PATH
: fish_add_path - add to the path — fish-shell 3.6.1 documentation
9acca9
8 November 2023 23:48
3
BluishHumility:
here it is
root=UUID=4e906687-8c77-4b83-9053-3b586eb81b12 rw rootflags=subvol=@
quiet resume=UUID=c2962ddb-91e8-4e83-87a5-4c2d77fcc58f loglevel=3 ibt=off
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ECS product: CMPC v: N/A serial: <superuser required>
Mobo: ECS model: Mobile PC serial: <superuser required>
UEFI: American Megatrends v: 2.03.00 date: 10/13/2021
ID-1: BAT1 charge: 21.3 Wh (70.1%) condition: 30.4/30.4 Wh (100.0%)
volts: 7.7 min: 7.6 model: Standard SF20GM7 type: Li-ion serial: <filter>
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 8 microcode: 0x22
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 796 min/max: 800/2800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 796 2: 796 bogomips: 4377
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: Elite Systems
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185
Device-2: SunplusIT USB 2M Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0a0a:24b1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model-id: STA 0x0002 built: 2021 res: 1366x768 dpi: 136
gamma: 1.2 size: 256x144mm (10.08x5.67") diag: 294mm (11.6") ratio: 16:9
modes: 1366x768
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 600 (GLK 2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:3185 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 16.0.6 128 bits) driver: mesa llvmpipe
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Elite Systems driver: snd_hda_intel v: kernel alternate: snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:3198
Device-2: C-Media USB Advanced Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 0d8c:025a class-ID: 0300
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlo2 state: up mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4
Local Storage: total: 447.13 GiB used: 7.9 GiB (1.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Neo Forza model: NFN025SA348-6000000
tech: SSD serial: <filter> fw-rev: 5A0 scheme: GPT
ID-1: / raw-size: 438.03 GiB size: 438.03 GiB (100.00%) used: 7.9 GiB (1.8%)
ID-3: /home raw-size: 438.03 GiB size: 438.03 GiB (100.00%)
used: 7.9 GiB (1.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 438.03 GiB size: 438.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 438.03 GiB size: 438.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.58 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2 dev: /dev/zram0
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 215 Uptime: 51m wakeups: 1 Memory: total: 8 GiB
available: 7.59 GiB used: 2.64 GiB (34.8%) Init: systemd v: 254
pm: pacman pkgs: 1264 libs: 414 tools: gnome-software,paru Shell: Bash
v: 5.2.15 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-06
Last full system update: 2023-11-08
PATH not PYTHONPATH anyways.
If you are using Bash then using .bashrc
is fine. It should look like this:
export PATH=$PATH:/home/myuser/.local/bin
system
Closed
23 November 2023 00:04
6
