Hello everyone, I've been dual booting Garuda with windows on 2 seperate SSDs and now I want to purge windows and use both of the SSDs as one. I've read on arch wiki that btrfs allows to do this without needing to do a clean install. But I don't have any idea about how to do this. I've formatted the other SSD with btrfs with mkfs. Thank you for your help.
Maybe
Do you want to
- Make both SSDs appear as a single partition (which is more difficult and more likely to result in data loss with a disk failure), or
- Make the additional SSD space available under a specific directory (which tends to be easier and keeps data held on one disk).
gleiche frage wie vorerst benannt
willst du wirklich 2 systeme vermischen also stripping
hast du zu wenig platz auf der einen hdd ????
benutze einfach fstabs
um die platte dauerhaft als speicher zu nutzen
beide systeme zu kreuzen oder so ist für mich eine komische forderung ich sehe darin kein mehrwert
same question as named for now
do you really want to mix 2 systems i.e. stripping
do you have too little space on one hdd ????
just use fstabs
to use the disk permanently as memory
crossing both systems or so is for me a strange request i see no added value in it
I want to use the other SSD as my steam library or my home directory
Thank you everyone, I instead booted into live USB and used genfstab and mounted it in a directory in my home filesystem. just seemed easier, sorry for wasting your time. thanks for all the advice
