ACS38U driver for Card reader BEID
I need this driver for my card reader !!!!!!
Can you help me . I have installed all software relative to BEID without result...
Raoul
Which driver?
Which software?
What result?
Please post !!!!! :
inxi -Fxxxza
lsusb
Have you installed and tested the acsccid driver?
No need ACR38U driver....
Solved by the following procedure used on Solus Os.
eID Belgium on Solus with Card Reader ACR38U
raoulgmail wrote: ↑
Install before EID-MW, EIDMW-FIREFOX, CCID and ACSCCID and run in a terminal the following commands
sudo systemctl enable pcscd.service ( very important to execute this command )
sudo systemctl start pcscd.service ( very important to execute this command )
SOLVED..............................
raoul
13/06/2018
