Hi!
This is my first post on this forum and with this occasion I also want to say that I love this Garuda project! I've recently moved from Windows and so far I have had no problem in using Garuda, everything you guys made is very easy and intuitive to use - also, the forum layout, and overall aesthetic is so nice! I hope this project runs indefinitely and keeps on getting better, and good luck to the devs (i hope they are called devs xd)
TLDR: I have some errors in journalctl, dont know why they are there, and came here to ask you if they are harmless, meanwhile maybe learning something new from you
I have been running this OS for the past 2 or 3 weeks and so far I haven't had any issues apart from 2 crashes (or rather one crash and one freeze). One happened 7-6 days or so ago, and the other the next day. The crash was a complete black screen, while I was playing League of Legends on lutris. I was already in my 3rd match, when at the 8th minute or so, just black screen. PC fan and leds restart, but pc didn't automatically boot again. I just long press the power button, (it shuts completely down) then press power button again and everything worked normally until next day. I was minding my day, after 2 hours or so when I was on chromium, opened YouTube tab, and then screen froze. Pressing caps didn't light up the caps button on keyboard, quick press power button didn't shut down the pc, sadly I have read only recently that i should've tried ssh'd into the host but I didn't know at the time.
In the meantime, I have changed the C state in bios as read here
Since then I haven't had the issue again, but I've started being interested in reading on how to fix it, I've learned how to read the journalctl log thing, I've tried going back in time to when the crash happened but couldn't seem to find anything out of the ordinary.
This is the garuda-inxi
command
╭─hexie@ROK in ~
╰─λ garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "ro_RO.UTF-8",
LC_NAME = "ro_RO.UTF-8",
LC_MONETARY = "ro_RO.UTF-8",
LC_PAPER = "ro_RO.UTF-8",
LC_IDENTIFICATION = "ro_RO.UTF-8",
LC_TELEPHONE = "ro_RO.UTF-8",
LC_MEASUREMENT = "ro_RO.UTF-8",
LC_TIME = "en_GB.UTF-8",
LC_NUMERIC = "ro_RO.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 5.19.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=69cb4a22-33d6-4af4-8a49-29a7895df4d2 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2301
date: 04/19/2019
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001137
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3309 high: 3393 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3200 2: 3392
3: 3200 4: 3200 5: 3200 6: 3380 7: 3392 8: 3375 9: 3393 10: 3392 11: 3392
12: 3200 bogomips: 76652
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: DP-2,DP-3 empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 09:00.0
Device-2: MacroSilicon USB Video type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 3-2:2
chip-ID: 534d:2109 class-ID: 0300
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: HP ZR2440w
serial: <filter> built: 2012 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
Monitor-2: DP-3 mapped: DisplayPort-2 pos: primary,right
model: Asus BE24A serial: <filter> built: 2016 res: 1920x1200 hz: 60
dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
ratio: 16:10 modes: max: 1920x1200 min: 640x480
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM
3.47 5.19.11-zen1-1-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
vendor: XFX Pine driver: snd_hda_intel bus-ID: 3-2:2 v: kernel
chip-ID: 534d:2109 pcie: class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: MacroSilicon USB Video type: USB
Sound Server-1: ALSA v: k5.19.11-zen1-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Local Storage: total: 476.94 GiB used: 82.65 GiB (17.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Plextor model: PX-512M9PeG
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1.07
temp: 44.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 82.65 GiB
(17.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 82.65
GiB (17.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 82.65
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 82.65
ID-1: swap-1 type: zram size: 15.54 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: 38.8 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 883
Processes: 342 Uptime: 29m wakeups: 0 Memory: 15.55 GiB used: 4.01 GiB
(25.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1531 libs: 443
tools: octopi,paru,yay pm: flatpak pkgs: 0 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-09-18
Last full system update: 2022-09-27
What I did find though are these errors
In journalctl -b -p err
journalctl (also pastebin because I exceeded body limit)
And also in dmesg (sorry if I put it in pastebin, but this output is so long)
I don't seem to run into any crashes or bugs lately, but maybe they were because of these?
So far I googled around, and for the ACPI error I have no problems that other people encounter related to the error (nothing that I know how to test at least)
For the xdg-desktop-portal-kde[2929]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
I have looked into processes and it seems to be running without me restarting it, but I don't know why the error appears.
Also btrfs-assistant is running as well, and the bashrc initial setup seems to be successful (any way to check what bashrc setup it's talking about?)
The only bug I have is that KDE connect doesnt automatically connect to my phone, I have to restart the kdeconnectd then it does, but i dont this its related to any of these.
Is there any way to clean up these errors so maybe they don't appear in the future?
Or is this just common and should be ignored (kinda pressing on my ocd though)
I'm also hoping of maybe learning something new out of these things
Thanks for the help! (and hope I didn't open just another useless topic)
(I also hope I formatted things nicely, I tried following the guides)
