While trying to fix the issue of kde plasma desktop turning into a hybrid mismatch with dragonized desktop upon startup, I decided to remove a file, and then another.
The second one I removed fixed the issue, but now my desktop no longer works properly.
Can someone please check their autostart and give me the location of those two files so I can add them back? Thanks alot haha.
Would have been nice if that had been in the first post.
Can you please submit your garuda-inxi.
Did you check in /etc/skel if the files are there, for copy and paste to your home folder?
Did you try garuda-assistant to restore?
