whats the better to install garuda: in external hard disk or internal hard disk ?
Internal hard disk, because it is usually faster.
And welcome to the community.
Also because external drives have risk of loose cable disconnecting
thnx my dear thats what i meant ,the system speed
thnx dear ihats what i want
Normally internal is faster, but this depends on the disk type and external connection.
I'd say also that external installation could be a bit more delicate.
If I remember correctly at least you need to create the ESP partition there.
And external disks can have problems with changing UUID in some conditions (IIRC)
It will, for example, stay unique even if the device is plugged into another system (which may perhaps have a device with the same label)
