About alacritty copy and paste text
I am tired about Ctrl + shift + C
So I change the config. The selected text will be copied to the primary clipboard.
Funny, I edit some “values” and in the terminal I got help to the new syntax.
Why the standard yml get not the new values as default?
See diff with meld, make a backup from your yml and send here nicer configurations.
I search for, mark all text, key shortcut.
alacritty.yml
# Configuration for Alacritty, the GPU enhanced terminal emulator.
# Any items in the `env` entry below will be added as
# environment variables. Some entries may override variables
# set by alacritty itself.
env:
  # TERM variable
  # This value is used to set the `$TERM` environment variable for
  # each instance of Alacritty. If it is not present, alacritty will
  # check the local terminfo database and use `alacritty` if it is
  # available, otherwise `xterm-256color` is used.
  TERM: xterm-256color
window:
  # Window dimensions (changes require restart)
  # Specified in number of columns/lines, not pixels.
  # If both are `0`, this setting is ignored.
  #dimensions:
  #  columns: 0
  #  lines: 0
  # Window position (changes require restart)
  # Specified in number of pixels.
  # If the position is not set, the window manager will handle the placement.
  #position:
  #  x: 0
  #  y: 0
  # Window padding (changes require restart)
  # Blank space added around the window in pixels. This padding is scaled
  # by DPI and the specified value is always added at both opposing sides.
  #padding:
  #  x: 0
  #  y: 0
  # Spread additional padding evenly around the terminal content.
  dynamic_padding: true
  # Window decorations
  # Values for `decorations`:
  #     - full: Borders and title bar
  #     - none: Neither borders nor title bar
  # Values for `decorations` (macOS only):
  #     - transparent: Title bar, transparent background and title bar buttons
  #     - buttonless: Title bar, transparent background, but no title bar buttons
  decorations: full
  # Startup Mode (changes require restart)
  # Values for `startup_mode`:
  #   - Windowed
  #   - Maximized
  #   - Fullscreen
  # Values for `startup_mode` (macOS only):
  #   - SimpleFullscreen
  #startup_mode: Windowed
  # Window title
  title: Garudas Alacritty
  # Window class (Linux/BSD only):
  #class:
    # Application instance name
    #instance: Alacritty
    # General application class
    #general: Alacritty
  # GTK theme variant (Linux/BSD only)
  # Override the variant of the GTK theme. Commonly supported values are `dark` and `light`.
  # Set this to `None` to use the default theme variant.
  gtk_theme_variant: dark
scrolling:
  # Maximum number of lines in the scrollback buffer.
  # Specifying '0' will disable scrolling.
  history: 99999
  # Scrolling distance multiplier.
  multiplier: 3
# Font configuration
font:
  # Normal (roman) font face
  normal:
    # Font family
    # Default:
    #   - (macOS) Menlo
    #   - (Linux/BSD) monospace
    #   - (Windows) Consolas
    family: Source Code Pro
    # The `style` can be specified to pick a specific face.
    #style: Regular
  # Bold font face
  bold:
    # Font family
    # If the bold family is not specified, it will fall back to the
    # value specified for the normal font.
    #style: Bold
  # Italic font face
  italic:
    # Font family
    # If the italic family is not specified, it will fall back to the
    #style: Italic
  # Bold italic font face
  bold_italic:
    # Font family
    # If the bold italic family is not specified, it will fall back to the
    #style: Bold Italic
  # Point size
  # Offset is the extra space around each character. `offset.y` can be thought of
  # as modifying the line spacing, and `offset.x` as modifying the letter spacing.
  #offset:
  #  x: 0
  #  y: 0
  # Glyph offset determines the locations of the glyphs within their cells with
  # the default being at the bottom. Increasing `x` moves the glyph to the right,
  # increasing `y` moves the glyph upwards.
  #glyph_offset:
  #  x: 0
  #  y: 0
  # Thin stroke font rendering (macOS only)
  # Thin strokes are suitable for retina displays, but for non-retina screens
  # it is recommended to set `use_thin_strokes` to `false`.
  #use_thin_strokes: true
# If `true`, bold text is drawn using the bright color variants.
draw_bold_text_with_bright_colors: true
# Colors (Tomorrow Night)
#colors:
  # Default colors
  #primary:
  #  background: '#1d1f21'
  #  foreground: '#c5c8c6'
    # Bright and dim foreground colors
    # The dimmed foreground color is calculated automatically if it is not present.
    # If the bright foreground color is not set, or `draw_bold_text_with_bright_colors`
    # is `false`, the normal foreground color will be used.
    #dim_foreground: '#828482'
    #bright_foreground: '#eaeaea'
  # Cursor colors
  # Colors which should be used to draw the terminal cursor. If these are
  # unset, the cursor color will be the inverse of the cell color.
  #cursor:
  #  text: '#000000'
  #  cursor: '#ffffff'
  # Vi mode cursor colors
  # Colors for the cursor when the vi mode is active. If these are unset, the
  # cursor color will be the inverse of the cell color.
  #vi_mode_cursor:
  #  text: '#000000'
  #  cursor: '#ffffff'
  # Selection colors
  # Colors which should be used to draw the selection area. If selection
  # background is unset, selection color will be the inverse of the cell colors.
  # If only text is unset the cell text color will remain the same.
  #selection:
  #  text: '#eaeaea'
  #  background: '#404040'
  # Normal colors
  #normal:
  #  black:   '#1d1f21'
  #  red:     '#cc6666'
  #  green:   '#b5bd68'
  #  yellow:  '#f0c674'
  #  blue:    '#81a2be'
  #  magenta: '#b294bb'
  #  cyan:    '#8abeb7'
  #  white:   '#c5c8c6'
  # Bright colors
  #bright:
  #  black:   '#666666'
  #  red:     '#d54e53'
  #  green:   '#b9ca4a'
  #  yellow:  '#e7c547'
  #  blue:    '#7aa6da'
  #  magenta: '#c397d8'
  #  cyan:    '#70c0b1'
  #  white:   '#eaeaea'
  # Dim colors
  # If the dim colors are not set, they will be calculated automatically based
  # on the `normal` colors.
  #dim:
  #  black:   '#131415'
  #  red:     '#864343'
  #  green:   '#777c44'
  #  yellow:  '#9e824c'
  #  blue:    '#556a7d'
  #  magenta: '#75617b'
  #  cyan:    '#5b7d78'
  #  white:   '#828482'
  # Indexed Colors
  # The indexed colors include all colors from 16 to 256.
  # When these are not set, they're filled with sensible defaults.
  # Example:
  #   `- { index: 16, color: '#ff00ff' }`
  #indexed_colors: []
# Visual Bell
# Any time the BEL code is received, Alacritty "rings" the visual bell. Once
# rung, the terminal background will be set to white and transition back to the
# default background color. You can control the rate of this transition by
# setting the `duration` property (represented in milliseconds). You can also
# configure the transition function by setting the `animation` property.
# Values for `animation`:
#   - Ease
#   - EaseOut
#   - EaseOutSine
#   - EaseOutQuad
#   - EaseOutCubic
#   - EaseOutQuart
#   - EaseOutQuint
#   - EaseOutExpo
#   - EaseOutCirc
#   - Linear
# Specifying a `duration` of `0` will disable the visual bell.
#visual_bell:
#  animation: EaseOutExpo
#  duration: 0
#  color: '#ffffff'
# Background opacity
# Window opacity as a floating point number from `0.0` to `1.0`.
# The value `0.0` is completely transparent and `1.0` is opaque.
background_opacity: 0.9
#selection:
  #semantic_escape_chars: ",│`|:\"' ()[]{}<>\t"
  # When set to `true`, selected text will be copied to the primary clipboard.
save_to_clipboard: true
# Allow terminal applications to change Alacritty's window title.
window.dynamic_title: true
#cursor:
  # Cursor style
  # Values for `style`:
  #   - ▇ Block
  #   - _ Underline
  #   - | Beam
  #style: Block
  # Vi mode cursor style
  # If the vi mode cursor style is `None` or not specified, it will fall back to
  # the style of the active value of the normal cursor.
  # See `cursor.style` for available options.
  #vi_mode_style: None
  # If this is `true`, the cursor will be rendered as a hollow box when the
  # window is not focused.
  #unfocused_hollow: true
  # Thickness of the cursor relative to the cell width as floating point number
  # from `0.0` to `1.0`.
  #thickness: 0.15
# Live config reload (changes require restart)
#live_config_reload: true
# Shell
# You can set `shell.program` to the path of your favorite shell, e.g. `/bin/fish`.
# Entries in `shell.args` are passed unmodified as arguments to the shell.
# Default:
#   - (macOS) /bin/bash --login
#   - (Linux/BSD) user login shell
#   - (Windows) powershell
#shell:
#  program: /bin/bash
#  args:
#    - --login
# Startup directory
# Directory the shell is started in. If this is unset, or `None`, the working
# directory of the parent process will be used.
#working_directory: None
# WinPTY backend (Windows only)
# Alacritty defaults to using the newer ConPTY backend if it is available,
# since it resolves a lot of bugs and is quite a bit faster. If it is not
# available, the the WinPTY backend will be used instead.
# Setting this option to `true` makes Alacritty use the legacy WinPTY backend,
# even if the ConPTY backend is available.
#winpty_backend: false
# Send ESC (\x1b) before characters when alt is pressed.
#alt_send_esc: true
mouse:
  # Click settings
  # The `double_click` and `triple_click` settings control the time
  # alacritty should wait for accepting multiple clicks as one double
  # or triple click.
  #double_click: { threshold: 300 }
  #triple_click: { threshold: 300 }
  # If this is `true`, the cursor is temporarily hidden when typing.
  hide_when_typing: true
  #url:
    # URL launcher
    # This program is executed when clicking on a text which is recognized as a URL.
    # The URL is always added to the command as the last parameter.
    # When set to `launcher: None`, URL launching will be disabled completely.
    # Default:
    #   - (macOS) open
    #   - (Linux/BSD) xdg-open
    #   - (Windows) explorer
    #launcher:
    #  program: xdg-open
    #  args: []
    # URL modifiers
    # These are the modifiers that need to be held down for opening URLs when clicking
    # on them. The available modifiers are documented in the key binding section.
    #modifiers: None
# Mouse bindings
# Mouse bindings are specified as a list of objects, much like the key
# bindings further below.
# To trigger mouse bindings when an application running within Alacritty captures the mouse, the
# `Shift` modifier is automatically added as a requirement.
# Each mouse binding will specify a:
# - `mouse`:
#   - Middle
#   - Left
#   - Right
#   - Numeric identifier such as `5`
# - `action` (see key bindings)
# And optionally:
# - `mods` (see key bindings)
#mouse_bindings:
#  - { mouse: Middle, action: PasteSelection }
# Key bindings
# Key bindings are specified as a list of objects. For example, this is the
# default paste binding:
# `- { key: V, mods: Control|Shift, action: Paste }`
# Each key binding will specify a:
# - `key`: Identifier of the key pressed
#    - A-Z
#    - F1-F24
#    - Key0-Key9
#    A full list with available key codes can be found here:
#    https://docs.rs/glutin/*/glutin/event/enum.VirtualKeyCode.html#variants
#    Instead of using the name of the keys, the `key` field also supports using
#    the scancode of the desired key. Scancodes have to be specified as a
#    decimal number. This command will allow you to display the hex scancodes
#    for certain keys:
#       `showkey --scancodes`.
# Then exactly one of:
# - `chars`: Send a byte sequence to the running application
#    The `chars` field writes the specified string to the terminal. This makes
#    it possible to pass escape sequences. To find escape codes for bindings
#    like `PageUp` (`"\x1b[5~"`), you can run the command `showkey -a` outside
#    of tmux. Note that applications use terminfo to map escape sequences back
#    to keys. It is therefore required to update the terminfo when changing an
#    escape sequence.
# - `action`: Execute a predefined action
#   - ToggleViMode
#   - Copy
#   - Paste
#   - PasteSelection
#   - IncreaseFontSize
#   - DecreaseFontSize
#   - ResetFontSize
#   - ScrollPageUp
#   - ScrollPageDown
#   - ScrollLineUp
#   - ScrollLineDown
#   - ScrollToTop
#   - ScrollToBottom
#   - ClearHistory
#   - Hide
#   - Minimize
#   - Quit
#   - ToggleFullscreen
#   - SpawnNewInstance
#   - ClearLogNotice
#   - ClearSelection
#   - ReceiveChar
#   - None
#   (`mode: Vi` only):
#   - Open
#   - Up
#   - Down
#   - Left
#   - Right
#   - First
#   - Last
#   - FirstOccupied
#   - High
#   - Middle
#   - Low
#   - SemanticLeft
#   - SemanticRight
#   - SemanticLeftEnd
#   - SemanticRightEnd
#   - WordRight
#   - WordLeft
#   - WordRightEnd
#   - WordLeftEnd
#   - Bracket
#   - ToggleNormalSelection
#   - ToggleLineSelection
#   - ToggleBlockSelection
#   - ToggleSemanticSelection
#   (macOS only):
#   - ToggleSimpleFullscreen: Enters fullscreen without occupying another space
#   (Linux/BSD only):
#   - CopySelection: Copies into selection buffer
# - `command`: Fork and execute a specified command plus arguments
#    The `command` field must be a map containing a `program` string and an
#    `args` array of command line parameter strings. For example:
#       `{ program: "alacritty", args: ["-e", "vttest"] }`
# And optionally:
# - `mods`: Key modifiers to filter binding actions
#    - Command
#    - Control
#    - Option
#    - Super
#    - Shift
#    - Alt
#    Multiple `mods` can be combined using `|` like this:
#       `mods: Control|Shift`.
#    Whitespace and capitalization are relevant and must match the example.
# - `mode`: Indicate a binding for only specific terminal reported modes
#    This is mainly used to send applications the correct escape sequences
#    when in different modes.
#    - AppCursor
#    - AppKeypad
#    - Alt
#    A `~` operator can be used before a mode to apply the binding whenever
#    the mode is *not* active, e.g. `~Alt`.
# Bindings are always filled by default, but will be replaced when a new
# binding with the same triggers is defined. To unset a default binding, it can
# be mapped to the `ReceiveChar` action. Alternatively, you can use `None` for
# a no-op if you do not wish to receive input characters for that binding.
# If the same trigger is assigned to multiple actions, all of them are executed
# at once.
#key_bindings:
  #- { key: Paste,                                action: Paste          }
  #- { key: Copy,                                 action: Copy           }
  #- { key: L,         mods: Control,             action: ClearLogNotice }
  #- { key: L,         mods: Control, mode: ~Vi,  chars: "\x0c"          }
  #- { key: PageUp,    mods: Shift,   mode: ~Alt, action: ScrollPageUp,  }
  #- { key: PageDown,  mods: Shift,   mode: ~Alt, action: ScrollPageDown }
  #- { key: Home,      mods: Shift,   mode: ~Alt, action: ScrollToTop,   }
  #- { key: End,       mods: Shift,   mode: ~Alt, action: ScrollToBottom }
  # Vi Mode
  #- { key: Space,  mods: Shift|Control, mode: Vi, action: ScrollToBottom          }
  #- { key: Space,  mods: Shift|Control,           action: ToggleViMode            }
  #- { key: Escape,                      mode: Vi, action: ClearSelection          }
  #- { key: I,                           mode: Vi, action: ScrollToBottom          }
  #- { key: I,                           mode: Vi, action: ToggleViMode            }
  #- { key: Y,      mods: Control,       mode: Vi, action: ScrollLineUp            }
  #- { key: E,      mods: Control,       mode: Vi, action: ScrollLineDown          }
  #- { key: G,                           mode: Vi, action: ScrollToTop             }
  #- { key: G,      mods: Shift,         mode: Vi, action: ScrollToBottom          }
  #- { key: B,      mods: Control,       mode: Vi, action: ScrollPageUp            }
  #- { key: F,      mods: Control,       mode: Vi, action: ScrollPageDown          }
  #- { key: U,      mods: Control,       mode: Vi, action: ScrollHalfPageUp        }
  #- { key: D,      mods: Control,       mode: Vi, action: ScrollHalfPageDown      }
  #- { key: Y,                           mode: Vi, action: Copy                    }
  #- { key: Y,                           mode: Vi, action: ClearSelection          }
  #- { key: Copy,                        mode: Vi, action: ClearSelection          }
  #- { key: V,                           mode: Vi, action: ToggleNormalSelection   }
  #- { key: V,      mods: Shift,         mode: Vi, action: ToggleLineSelection     }
  #- { key: V,      mods: Control,       mode: Vi, action: ToggleBlockSelection    }
  #- { key: V,      mods: Alt,           mode: Vi, action: ToggleSemanticSelection }
  #- { key: Return,                      mode: Vi, action: Open                    }
  #- { key: K,                           mode: Vi, action: Up                      }
  #- { key: J,                           mode: Vi, action: Down                    }
  #- { key: H,                           mode: Vi, action: Left                    }
  #- { key: L,                           mode: Vi, action: Right                   }
  #- { key: Up,                          mode: Vi, action: Up                      }
  #- { key: Down,                        mode: Vi, action: Down                    }
  #- { key: Left,                        mode: Vi, action: Left                    }
  #- { key: Right,                       mode: Vi, action: Right                   }
  #- { key: Key0,                        mode: Vi, action: First                   }
  #- { key: Key4,   mods: Shift,         mode: Vi, action: Last                    }
  #- { key: Key6,   mods: Shift,         mode: Vi, action: FirstOccupied           }
  #- { key: H,      mods: Shift,         mode: Vi, action: High                    }
  #- { key: M,      mods: Shift,         mode: Vi, action: Middle                  }
  #- { key: L,      mods: Shift,         mode: Vi, action: Low                     }
  #- { key: B,                           mode: Vi, action: SemanticLeft            }
  #- { key: W,                           mode: Vi, action: SemanticRight           }
  #- { key: E,                           mode: Vi, action: SemanticRightEnd        }
  #- { key: B,      mods: Shift,         mode: Vi, action: WordLeft                }
  #- { key: W,      mods: Shift,         mode: Vi, action: WordRight               }
  #- { key: E,      mods: Shift,         mode: Vi, action: WordRightEnd            }
  #- { key: Key5,   mods: Shift,         mode: Vi, action: Bracket                 }
  # (Windows, Linux, and BSD only)
  #- { key: V,        mods: Control|Shift,           action: Paste            }
  #- { key: C,        mods: Control|Shift,           action: Copy             }
  #- { key: C,        mods: Control|Shift, mode: Vi, action: ClearSelection   }
  #- { key: Insert,   mods: Shift,                   action: PasteSelection   }
  #- { key: Key0,     mods: Control,                 action: ResetFontSize    }
  #- { key: Equals,   mods: Control,                 action: IncreaseFontSize }
  #- { key: Add,      mods: Control,                 action: IncreaseFontSize }
  #- { key: Subtract, mods: Control,                 action: DecreaseFontSize }
  #- { key: Minus,    mods: Control,                 action: DecreaseFontSize }
  # (Windows only)
  #- { key: Return,   mods: Alt,           action: ToggleFullscreen }
  # (macOS only)
  #- { key: K,      mods: Command, mode: ~Vi, chars: "\x0c"            }
  #- { key: Key0,   mods: Command,            action: ResetFontSize    }
  #- { key: Equals, mods: Command,            action: IncreaseFontSize }
  #- { key: Add,    mods: Command,            action: IncreaseFontSize }
  #- { key: Minus,  mods: Command,            action: DecreaseFontSize }
  #- { key: K,      mods: Command,            action: ClearHistory     }
  #- { key: V,      mods: Command,            action: Paste            }
  #- { key: C,      mods: Command,            action: Copy             }
  #- { key: C,      mods: Command, mode: Vi,  action: ClearSelection   }
  #- { key: H,      mods: Command,            action: Hide             }
  #- { key: M,      mods: Command,            action: Minimize         }
  #- { key: Q,      mods: Command,            action: Quit             }
  #- { key: W,      mods: Command,            action: Quit             }
  #- { key: N,      mods: Command,            action: SpawnNewInstance }
  #- { key: F,      mods: Command|Control,    action: ToggleFullscreen }
#debug:
  # Display the time it takes to redraw each frame.
  #render_timer: false
  # Keep the log file after quitting Alacritty.
  #persistent_logging: false
  # Log level
  # Values for `log_level`:
  #   - None
  #   - Error
  #   - Warn
  #   - Info
  #   - Debug
  #   - Trace
  #log_level: Warn
  # Print all received window events.
  #print_events: false
