Ableton Live 11 (and other) audio issues
Hello, i’ve been using Ableton Live 11 through wine for quite a while now, i never had any issues, it maybe just seemed a little slower than it should, i was able to turn down the output buffer size down to around 312 samples without any issues, sometimes the audio would pop but it was worth the low latency.
Yesterday i tried updating through garuda-update and even through pacman -Suy, both wanted to replace a ton of packages since it was maybe a couple of weeks since i last updated.
Pacman refused to update because replacing some of the packages would break dependencies, after a bit of googling i decided to use pacman -Suydd to ignore the breaking dependencies and updated fine, everything worked.
In the updated packages i noticed that pipewire was updating too.
Today, after starting Ableton, it said that the audio engine was off because no output device was selected, that was fine but it meant that the update changed audio i/o names.
I selected the new outputs and inputs and my ears almost died when i turned the buffer size below 5000 samples because ALL of the audio sounds incredibly robotic, i wouldnt say it cracks or pops, but sounds like its out of sync with whatever is trying to play it back. The audio only works okay at ~5000 samples buffer size, everything lower lags/sounds robotic and everything above lags.
I dont know whether to suspect pipewire or maybe an alsa update, no idea, im not really experienced with any of this.
One other thing ive noticed is a program ive been working on, which interacted with the pipewire server through an api in rust, when connecting sinks and sources SOMETIMES caused the audio to be choppy, which i suspected is maybe something like them becoming out of sync, didnt do research and said id fix it later. However now, EVERY time i connect two pipewire nodes together the audio is choppy and doesnt play back correctly.
Any help is appreciated since i have no idea how to go about this, google doesnt return many relevant articles about this thing, and when it comes to ableton it returns 0. Should i ask on pipewires github? Is this not a pipewire problem?
My driver type in ableton is: MME/DirectX
My input device in ableton is: Built-in Audio Analog Stereo Wave
My output device in ableton is: Built-in Audio Analog Stereo Wave
(Wave has never been in the device names before)
Some of the other devices are things like: PulseAudio Wave, PulseAudio DX and so on.
Thanks!
    root=UUID=3bf66fc0-89ba-4f98-b6f6-81b2ff1ff168 rw rootflags=subvol=@
    quiet rd.udev.log_priority=3 vt.global_cursor_default=0
    resume=UUID=fd7e8027-710d-411d-82b6-505a4c2b5304 loglevel=3
    nvidia-drm.modeset=1 ibt=off
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 vt: 2 dm: SDDM
  Type: Laptop System: Micro-Star product: GL62M 7REX v: REV:1.0
  Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E16J9IMS.31A date: 07/11/2017
  ID-1: BAT1 charge: 34.8 Wh (98.9%) condition: 35.2/42.4 Wh (83.2%)
    volts: 12.2 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: not charging
  Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
    model-id: 0x9E (158) stepping: 9 microcode: 0xF4
    desc: 1x6 MiB
  Speed (MHz): avg: 3123 high: 3146 min/max: 800/3500 scaling:
    driver: intel_pstate governor: performance cores: 1: 3146 2: 3134 3: 3100
    4: 3112 bogomips: 19999
  Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
    active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:591b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
    vendor: Micro-Star MSI driver: nvidia v: 535.113.01
    alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
  Device-3: Chicony [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-11:9 chip-ID: 04f2:b521 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 1052mm (41.43")
  Monitor-1: HDMI-A-2 mapped: HDMI-1-2 pos: primary,left
    model: Samsung LF24T35 serial: <filter> built: 2021 res: 1920x1080 hz: 60
    dpi: 92 gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9")
  Monitor-2: eDP-1 mapped: eDP-1-1 pos: right model: LG Display 0x0533
    built: 2016 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
    modes: 1920x1080
  API: EGL Message: No EGL data available.
  API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    memory: 1.95 GiB
  API: Vulkan v: 1.3.269 layers: 10 device: 0 type: integrated-gpu
    name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:591b surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: NVIDIA GeForce GTX 1050 Ti driver: nvidia v: 535.113.01
    device-ID: 10de:1c8c surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
  Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171
  API: ALSA v: k6.5.9-zen2-1-zen status: kernel-api
  Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI
    driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:8 chip-ID: 8087:0aa7
  Local Storage: total: 685.61 GiB used: 590.05 GiB (86.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBU-SNS8152S3256GG5
    tech: SSD serial: <filter> fw-rev: 01.R scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT480M500SSD1
    size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: MU03 scheme: MBR
  ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
    used: 208.6 GiB (90.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.54 GiB used: 1.54 GiB (9.9%)
    dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 74.0 C pch: 64.5 C mobo: N/A gpu: nvidia
    temp: 64 C
  Processes: 266 Uptime: 11h 26m wakeups: 4 Memory: total: 16 GiB
  available: 15.54 GiB used: 5.89 GiB (37.9%) Init: systemd v: 254
  Packages: 4024 pm: dpkg pkgs: 0 pm: pacman pkgs: 2008 libs: 532
  tools: octopi,paru,yay pm: rpm pkgs: N/A note: see --rpm tools: dnf
  pm: flatpak pkgs: 8 Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2021-11-26
  Last full system update: 2023-10-27 ↻
  Relevant software:       snapper connman mkinitcpio nvidia-dkms
  Failed units:            NetworkManager-wait-online.service NetworkManager.service
Bump?
