Catra
1
A recent upgrade to the kernel can change which framebuffer the linux console uses if you have a multi-gpu/multi-monitor set up.
If you need the console to appear on a different framebuffer (not which monitor, but which gpu) you add the following to GRUB_CMDLINE_LINUX_DEFAULT=
fbcon=map:x
Where x
is the framebuffer you want to use. (Starts at 0
HTH, Additions and corrections would be cool.
petsam
2
Would you mind posting links to relevant documentation, or any other helpful info?
tbg
3
Thanks for the helpful tip @Catra.
It's always nice to see you posting on the forum.
system
Closed
4
Catra
6
re this post:
the full, official documentation for fbcon:
https://www.kernel.org/doc/html/latest/fb/fbcon.html
