A problem with the NVIDIA drivers has been detected
Where is the list to start the update to raptor
It's this bookmarklet: GitHub - t-mart/kill-sticky: Bookmarklet to remove sticky elements and restore scrolling to web pages!
I requested it here: [enhancement] Add kill-sticky bookmarklet by default · Issue #47 · dr460nf1r3/firedragon-browser · GitHub
You can run garuda-update
have this error now
--> A problem with the NVIDIA drivers has been detected
---> Building NVIDIA DKMS module for kernel 6.2.6-arch1-1
--> Module nvidia 525.89.02 is not installed for kernel 6.2.6-arch1-1 (x86_64). Skipping...
--> Module nvidia 525.89.02 is not built for kernel 6.2.6-arch1-1 (x86_64). Skipping...
-->Sign command: /usr/lib/modules/6.2.6-arch1-1/build/scripts/sign-file
Binary /usr/lib/modules/6.2.6-arch1-1/build/scripts/sign-file not found, modules won't be signed
--> Error! Your kernel headers for kernel 6.2.6-arch1-1 cannot be found at /usr/lib/modules/6.2.6-arch1-1/build or /usr/lib/modules/6.2.6-arch1-1/source.
--> Please install the linux-headers-6.2.6-arch1-1 package or use the --kernelsourcedir option to tell DKMS where it's located.
---> Failed to build NVIDIA DKMS module for kernel 6.2.6-arch1-1
this was shown after a kernel update to 6.2.6-arch1-1
need help to fix
Thanks
Shawn
You post your problem in announcements, so you are missing the template if you open an help request.
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
So post your garuda-inxi as text. Format terminal text like.
then others can easily expand or copy the text.
then others can easily expand or copy the text in the view. Move the mouse pointer over it in the upper right corner.
Kernel: 6.2.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=47f16dfb-4a78-48be-b140-0b5f5eb94b94 rw rootflags=subvol=@
net.ifnames=0 rd.udev.log_priority=3 vt.global_cursor_default=0
loglevel=3 net.ifnames=0 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z68A-D3H-B3 v: N/A
serial: Chassis: type: 3 serial:
Mobo: Gigabyte model: Z68A-D3H-B3 v: x.x serial:
BIOS: Award v: F13 date: 03/20/2012
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard PID:005d
serial: N/A charge: 70% (should be ignored) rechargeable: yes
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse PID:0038
serial: N/A charge: 55% (should be ignored) rechargeable: yes
Device-3: hidpp_battery_2 model: Logitech ERGO M575 Trackball
serial: charge: 100% rechargeable: yes status: discharging
Info: model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3734 high: 3800 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3800 2: 3800 3: 3800
4: 3274 5: 3800 6: 3800 7: 3800 8: 3800 bogomips: 54560
Please Help
Thanks
Shawn
Please
Don’t sign your posts — every post has your profile information attached to it.
Keep It Tidy
Make the effort to put things in the right place, so that we can spend more time discussing and less cleaning up. So:
  • Don’t start a topic in the wrong category.
  • Don’t cross-post the same thing in multiple topics.
  • Don’t post no-content replies.
  • Don’t divert a topic by changing it midstream.
  • Don’t sign your posts — every post has your profile information attached to it.
Rather than posting “+1” or “Agreed”, use the Like button. Rather than taking an existing topic in a radically different direction, use Reply as a Linked Topic.
Sorry I am new to This Forum
We know :slight_smile:
Welcome, please, edit your posts.
got it to work did not have linux-headers installed for some reason
