Hello Garuda users.
I having a problem, with the installer of Garuda KDE Dragonized Gaming Edition. I getting a error every when a try to update my system.
Error:
error: failed retrieving file 'garuda-wallpapers-extra-r9.ef73a85-1-any.pkg.tar.zst' from geo-mirror.chaotic.cx : HTTP/2 stream 1 was not closed cleanly before end of the underlying stream
error: failed retrieving file 'samba-4.16.3-1-x86_64.pkg.tar.zst' from at.arch.mirror.Rescher.at : HTTP/2 stream 35 was not closed cleanly before end of the underlying stream
error: failed retrieving file 'Rfind-22.04.3-1-x86_64.pkg.tar.zst' from at.arch.mirror.Rescher.at : HTTP/2 stream 51 was not closed cleanly before end of the underlying stream
error: failed retrieving file 'Rgamma5-5.25.3-1x86_64.pkg.tar.zst' from at.arch.mirror.Rescher.at : HTTP/2 stream 57 was not closed cleanly before end of the underlying stream
warning: too many errors from at.arch.mirror.Rescher.at, sRipping for the remainder of this transaction
error: failed retrieving file 'Rhtml-5.96.0-1-x86_64.pkg.tar.zst' from at.arch.mirror.Rescher.at : HTTP/2 stream 59 was not closed cleanly before end of the underlying stream
(1416/1416) checking keys in keyring
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: keyring is not writable
etc
does anyone know a solution for this problem?
