5.8GB of 8GB Usable
This is windows 11, but yes I know what you're referring to about the Usable ram, but it does not shows that right now, I've seen that in other machines, not in these ones- heh
Alright here it is
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1917394f-b0c2-4c6c-a7d3-02e38e0d3198 rw rootflags=subvol=@
resume=UUID=23bb2582-0375-4d9a-9f4b-3d7ff29409c1 loglevel=3
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X509DJ_M509DJ
Mobo: ASUSTeK model: X509DJ v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X509DJ.304 date: 04/08/2020
ID-1: BAT0 charge: 7.0 Wh (28.8%) condition: 24.3/32.0 Wh (75.8%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 324
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1355 high: 1773 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1301 2: 1221
3: 1557 4: 1773 5: 1283 6: 1230 7: 1227 8: 1255 bogomips: 33536
STIBP: disabled, RSB filling
Device-1: NVIDIA GP108M [GeForce MX230] vendor: ASUSTeK driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d11
class-ID: 0302
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.2:5 chip-ID: 13d3:5a11 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ce v: N/A modules: rtw88_8821ce,8821ce
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-2: ICS Advent DM9601 Fast Ethernet Adapter type: USB
driver: dm9601 bus-ID: 1-4:3 chip-ID: 0fe6:9700 class-ID: 0000
IF: enp3s0f3u4 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2.1:4 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 223.57 GiB used: 46.82 GiB (20.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: 0101 scheme: GPT
ID-1: / raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
used: 46.82 GiB (21.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
ID-4: /var/log raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
ID-5: /var/tmp raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 5.8 GiB used: 633.5 MiB (10.7%)
System Temperatures: cpu: 70.0 C mobo: N/A gpu: amdgpu temp: 69.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 328 Uptime: 1h 47m wakeups: 5 Memory: 5.8 GiB
used: 4.18 GiB (72.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1929 lib: 354 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.11
Oh, I see what you mean now. That is odd!
What is the output of sudo dmidecode -t 17?
What is the output of free -m?
Well, it is not an issue, it is expected behavior. You have
That shares memory from your RAM as vram for integrated graphics.
This should be clearly mentioned in BIOS of your laptop. You can also adjust the vram for laptop, but this may introduce some problems in daily use.
Also you can search on search engine the title of this topic, to get further clarification.
Well, you're right but why is not shown in windows like that?
and about showing that in Bios nope... it actually doesn't show anything... perhaps I'll update Bios to check that, maybe is because it's an old firmware
It should be shown in windows too. See this for example
But I really don't know where it is shown.
I would prefer looking in bios for more reliability.
I don't see why this has to be explained over and over you can't compare windows and Linux windows does its thing its way to make windows look better for the consumer.
Linux does it the UNIX way so the user is well informed.
""If at first you don't get the answer you want, keep asking until you do."
Nice tag line for help vampires
:joy:
(kidding off course)
