I have an issue with nvidia drivers.
Im working on laptop MSI GS65 Stealth Thin. GTX-1070 max q. And my monitor wont work with nvidia drivers. I can install different drivers, but then 5fps in games...
Can I somehow get the monitor to work with nvidia?
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=513af750-1449-42cf-8e7b-f7e070bf072d
Console: tty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: Micro-Star product: GS65 Stealth Thin 8RF v: REV:1.0 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16Q2 v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16Q2IMS.112 date: 05/21/2019
Battery: ID-1: BAT1 charge: 67.3 Wh (96.3%) condition: 69.9/80.3 Wh (87.1%) volts: 17.1 min: 15.2
model: MSI BIF0_9 type: Li-ion serial: N/A status: Unknown
CPU: Info: 6-Core model: Intel Core i7-8750H socket: U3E1 bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L1: 384 KiB
L2: 9 MiB L3: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 52799
Speed: 3982 MHz min/max: 800/4100 MHz base/boost: 2100/8300 volts: 0.8 V ext-clock: 100 MHz
Core speeds (MHz): 1: 3982 2: 4001 3: 3994 4: 4000 5: 4001 6: 4000 7: 4000 8: 3999 9: 3967
10: 4000 11: 4000 12: 4000
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1ba1 class-ID: 0300
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi
vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi v: kernel port: 5000
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Micro-Star MSI driver: alx
v: kernel port: 3000 bus-ID: 3c:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Drives: Local Storage: total: 476.94 GiB used: 22.6 GiB (4.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000 size: 476.94 GiB
rev: EXA7201Q temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 133d 3h cycles: 2,902 read-units: 197,232,677 [100 TB]
written-units: 136,405,653 [69.8 TB]
Partition: ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 22.6 GiB (4.7%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 22.6 GiB (4.7%) fs: btrfs
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 22.6 GiB (4.7%) fs: btrfs
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 22.6 GiB (4.7%) fs: btrfs
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A
Info: Processes: 332 Uptime: 1h 0m wakeups: 1 Memory: 15.47 GiB used: 3.32 GiB (21.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1682 lib: 505
Shell: Bash (su) v: 5.1.8 running-in: konsole inxi: 3.3.06
dalto
12 August 2021 01:42
#2
Probably you can get it working.
However, you haven't provided the information we need to assist you. When you create a new topic the instructions for what are needed are clearly described. Please read through those again and share the information requested.
c00ter
12 August 2021 06:34
#3
That is a really nice way of putting it. Kudos, @dalto .
What information i can provide? Im new in linux
As dalto said, when you create a topic there is a list of guides on making good questions.The garuda team made it so for a reason
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your…
L2: 9 MiB L3: 9 MiB
diag: 394mm (15.5")
Sorry now im undand what info needed
Tru atleast 4 different kernels. linux
and linux-lts
would be good starters.
Try using drivers like Nvidia-all.
system
closed
27 August 2021 02:29
#8
