2 Keyboard shortcut issues
Only on one Garuda linux install do I have these odd issues.
  1. I need to switch between languages. I've tried various setting various key combinations, but regardless the action is the same. Basically when switching, regardless of which window I'm in, that window is no longer the active window. So I have to then click back into that window to be able to type. Really annoying...
  2. When switching between windows of the same application I like to use the Alt or Win + Apostrophe shortcut. This works UNLESS I have a file manager (Nautilus) window open. When switching between Applications (Alt or WIn + Tab) sometimes (not always) Nautilus will be in first place (on the left), so regardless of which app I'm in, if I want to switch to another Firefox window, Alt or Win + Apostrophe will take me to Nautilus. Only if I close Nautilus does App Window switching work as expected.
Kernel: 6.2.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=43f18a73-c753-4e08-9fba-b8afedfcb3ac rw [email protected]
resume=UUID=9431c5cc-6a40-4ec6-91b8-d397f24a4c4e loglevel=3 ibt=off
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Sony product: VPCZ21TGX v: J004MUHH
serial: Chassis: type: 10 serial:
Mobo: Sony model: VAIO serial: BIOS: INSYDE
v: R0170H5 date: 06/16/2011
ID-1: BAT1 charge: 0 Wh condition: N/A volts: N/A model: Sony Corporation
type: Li-ion serial: N/A status: not charging
Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 809 high: 843 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 843 2: 798 3: 798 4: 798
bogomips: 21550
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vendor: Sony driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: eDP-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0126
Device-2: Cheng Uei Precision Industry (Foxlink) Webcam type: USB
driver: uvcvideo bus-ID: 2-1.3:5 chip-ID: 05c8:0318 class-ID: 0e02
serial:
Display: x11 server: [X.Org](http://X.Org) v: 21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :1
Monitor-1: eDP-1 model: Sony LCD serial: built: 2011
res: 1920x1080 hz: 60 dpi: 168 gamma: 1.2 size: 291x164mm (11.46x6.46")
diag: 334mm (13.2") ratio: 16:9 modes: 1920x1080
missing.
vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound API: ALSA v: k6.2.1-zen1-1-zen running: yes
Device-1: Intel Centrino Advanced-N 6230 [Rainbow Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:0091 class-ID: 0280
IF: wlp2s0 state: up mac:
vendor: Sony driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 6000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF: enp5s0 state: down mac:
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB
driver: btusb v: 0.8 bus-ID: 2-1.2:4 chip-ID: 8086:0189 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address:
v: 3.0 port: a060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.49 GiB used: 66.93 GiB (28.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZRPC256HADR-000SO
type: SSD serial: rev: 3S1Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZRPC256HADR-000SO
ID-1: / raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
used: 66.93 GiB (60.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-3: /var/log raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-4: /var/tmp raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.71 GiB used: 919.2 MiB (15.7%)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 264 Uptime: 19m wakeups: 1 Memory: 5.71 GiB used: 4.5 GiB (78.9%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1568 libs: 493
tools: gnome-software,pamac,paru pm: flatpak pkgs: 0 Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-05-03
Last full system update: 2023-03-02
Relevant software: snapper(custom) NetworkManager mkinitcpio
Windows dual boot:
This one looks like a bug with Mutter: The window focus is lost after switching the input method (#2626) · Issues · GNOME / mutter · GitLab
You can either switch to Wayland which does not have the issue, or if you would rather stay on X11 you can downgrade Mutter.
sudo downgrade mutter
Try switching to a 43.2 version if you have one in your cache, or earlier if that doesn't work. You'll have to either re-check (and re-downgrade if it is still broken) after each time you update, or add it to your ignored packages for now in /etc/pacman.conf.
I cannot reproduce this, the function always works as expected when I test it. I have tried both Wayland and X11, and also a variety of applications but it never favors the file exporer and always switches between tasks of whichever application has focus.
Is it possible Nautilus has been opened by Firefox when this happens (as opposed to being opening from the launcher)? I'm just wondering if it might be being counted as a Firefox window for some reason.
Switching to Wayland seems to have fixed everything. As an aside, I always thought I was on Wayland. Seems like that should be the default.
I think for many distros, Wayland is the default for a Gnome DE. I'm not sure what the specific reason is that ours defaults to X11, but I believe our Gnome spin is between dedicated maintainers at the moment so that may have something to do with it.
Glad to hear the issues have been resolved. :+1:
